Supposedly fried (no explanation)
Snikku
This day a week ago:
While leaving my desktop in an idle state, and coming back to it, the screen had been frozen
Thinking that it was just a small error, i restarted
However, after restarting windows was running very slow and I thought that I had got some kind of virus
So after rebooting in safe mood, i ran system restore and the computer froze in that
Then after restarting another time, windows froze in the boot up screen
then it froze in the ram check for bios then it didnt even go into bios
freaked out, i let the computer cool off for 10 minutes and came back and it had the same nonboot
I called soyo and they said that my board was probably dead..
Im still trying to figure out the problem but the only explanation is that my heatsink malfunctioned some how and melted the cpu, other than that i can't think of anything besides a hardware failure
any ideas?
anyways im in the process of buying new stuff and I didn't regret losing the board/cpu other than using it as a server or something to stay at home, so i can use it when i come home from college...
Summoner
I doubt your CPU melted - if that was the case you wouldnt get any boot at all right from the start. Maybe you have a bad solder joint somewhere and with heat cycling it just failed over time.
Snikku
well yeah I did notice some random restarts eariler in the week but nothing like total failure as it happened there
is there anyway to fix that?
Summoner
I would RMA it if you can. You may get lucky and find the break or problem somewhere, but if one part has failed, its a good chance the board will never be right.
potroast
yep, sounds like either faulty RAM or bad board. In either case, you can't fix it easily, so look at RMAing the product or getting new ones.
Snikku
lol.. what do blown capacitors look like?
cuz they look perfectly normal to me
Snikku
i think that i got a bios virus that screwed it up, but my friends think that would never happen :confused:
oh well all of my new computer stuff came in today so im going to start installing it all and stop worrying about my old comp, if i can get it back up thats cool, but i would only use it as a server ;)
Danith
Hello.. new here, but been browsing for awhile ;)
Anyways, what brand MB was it? I have a SOYO 6BA+ IV that 'blew up' a couple weeks ago... had basically the same symptoms you described, finally the computer didn't turn on anymore. I got around to taking everything apart, and a component (voltage regulater I think) literally fried.. had a little hole-burn mark in it and you could smell the burnt electronics smell.. anyways, might wanna check your motherboard. If I had a digital camera, I would take a picture of the component, but there are a series of 4 by the CPU, 3 contact black chips...
Snikku
wow lol, i thought that never happens
but it was a SOYO K7ADA 1.0
and i never screwed with it either :confused:
MooCow
No wonder Newegg was giving out SOYO Dragon boards for free after rebate.... I kinda figuired there was some catch, and this catch might bite you in the ass down the road as it seems. :rolleyes:
Danith
Doh! my bad.. had a migraine last night, and that kinda messes up my thinking :)
It was actually a ECS K7S5A that fried... my SOYO is doing fine :)
Warrior
omg..i had one of thoes boards..loved to fry AMDs in it :) then got a MSI and sold it and got my Gigabyte and P4...will never go back to amd again :D
Snikku
same, i got a gigabyte P4 3.0GHZ
i mean the last board wasnt bad before it died, oh well no more AMD
