SuperSpeed USB 3.0 FAQ
HardOCP News
[H] News
Anyone with questions about the new USB 3.0 spec should check out the new SuperSpeed USB 3.0 FAQ brought to you by the guys at EverythingUSB.
Dubbed "SuperSpeed USB", USB 3.0 promises a major leap forward in transfer speeds and capability, while maintaining backwards compatibility with USB 2.0 devices. It may sound straightforward, but a lot has had to change; in this FAQ we will address the most common questions about USB 3.0 and explain in plain English what it all means.
USB 3.0 achieves the much higher performance by way of a number of technical changes. Perhaps the most obvious change is an additional physical bus that is added in parallel with the existing USB 2.0 bus. This means that where USB 2.0 previously had 4 wires (power, ground, and a pair for differential data), USB 3.0 adds 4 more for two pairs of differential signals (receive and transmit) for a combined total of 8 connections in the connectors and cabling. These extra two pairs were necessary to support the SuperSpeed USB target bandwidth requirements, because the two wire differential signals of USB 2.0 were not enough.
When serial isn't enough... start going moar parallel...
SuperSpeed? Come on. Why do they feel the need to add some "prefix" to the spec. Just call it USB 3.0. As long as they don't come out with another 3.0 that adds more speed, consumers will be fine. What will USB 4.0 be? LudicrousSpeed?
it will be called ultra speed silly.
The only really important question is, will it still be extremely cheap?
I thought the whole point about USB was to have a cheap connection for low-bandwidth items like mice and keyboards, rather than plugging them in using expensive connections like SATA. Somewhere along the way they started plugging in all manner of high-bandwidth items like hard drives and even monitors. Now it's actually attempting to compete with SATA, Firewire, etc.
I'm not trying to be a Luddite here, but it doesn't seem to me like it is appropriate to continually improve the performance of USB. Instead they should have kept it a very simple, very cheap, very long-term standard, and left the high-bandwidth stuff to SATA.
Those in charge of USB development are probably looking after their own interests (and not sata's) so therefore they're following the trend of ... improve or be replaced by a newer better product.
Of course consumers already have the choices you mentioned. Want a faster external hard drive? Then get an eSata model. On the flipside, the cheap long-term standard stuff is already USB. And the fact that USB3.0 is reverse compatible with USB2.0 ensures that these older USB products will remain viable for a while longer.
Besides, the consumer often reaps the benefits of competing products or standards. We'll purchase the fastest, most stable or least expensive choice available to us (wouldn't it be dandy if we could have all three in one package)
I'd love to see it continue to increase in speed.
Manufacturers have established it as a more de-facto standard than even Firewire, so IMO as long as they still do, no use you can't get faster throughput and actually some some higher performance hard disks on them.
But you also have to cater to the people that gripe about things like the speed of their flash drives, etc. With USB drives hitting 32gb and beyond now, people are moving around larger files that USB didn't have to worry about before. And of course, people will bitch because it's slow goin' for that pirated blu-ray movie to transfer.:p
Bigger, faster, stronger, just like all things tech.......
Geez, why not call it "Universal Parallel Bus" or UPB if it's going to transmit data in parallel? Words (and acronyms) mean things, ya know.
so 300-600 megs per second or around half a gig per second? how would we use or need that? Are these "camcorders" that supposedly need it going to be running 6 SSD drives in Raid 0 for storage in 2010? and are we all going to have 500+MBs hard drive setups to accept the data by then? Intel better really get to work on those flash drives!
for the new logitech HC9x3.0 particle colliding mouse...nothing screams precision like sniping someone into a black hole
Hahahah!
Yeah, I think they should have left high speed transfers to SATA or, at the very least, changed the name from USB to UPB, c'mon. For faster transfer rates on flash drives they could have just started making SATA Flash drives.
I could use that. USB 2.0 is painfully slow on large transfers.
Wish my drive setup was that fast!
Speaking of which, somone said something about competing with SATA. Wouldn't this be fast enough to replace SATA and even power the drives?
I bet you were one of those folks that said we'd never be using 8GB of RAM in desktop computers too because 8MB is plenty :D
still waiting for the day when my cellphone just plugs into a monitor and communicates with a full size keyboard/mouse via btooth.
yeah sata flash drives would have worked :). eventually i'll put a flash harddrive into my 2.5 inch enclosure :D. have to be much cheaper first ;)
Not to far off actually, Intel is doing an internal 4 disc Raid 0 on the new SSD they are working on. I think quite a few manufactures will be doing this, I had wondered why they had not already back 2 years ago.
I just got an eSATA HD enclosure for my laptop and was kind of miffed to discover I still needed to power it with a USB cable. Why the hell didn't they work that into the eSATA spec? 2 cords ftl but the speed is better than standard USB.
If this new standard is faster than eSATA I'll be happy just because it is one cord vs two.
