- Nov 27, 2006
Symwave is at CES in Las Vegas to demo the SuperSpeed USB 3.0 transfer capabilities on external HDDs. They were showing off their stuff and Engadget was there with a video camera to catch it. Intriguing.
When do the USB 3.0 enabled boards come out is my question. I've got an old computer, and I don't want to upgrade if 3.0 is just around the corner. Had that happen with this one.
Actually, he said "Three Dot Oh."Stop saying "Three Dot Zero" you sound like a fucking tard.
In a few years when it becoems mainstreamish we'll all be using SSDs making it a moot point.Speed is good and all, but I'd like to see USB being able to provide 12 volt power. As it is, there's no reason for me to use it over eSATA for my external 3.5 hard drives since I still have to plug in external power.
Silly display. Demoing a 500MBs technology through a PCI bus (133MBs) to a regular HDD (~80MBs.) If you're going to show off a technology that's ~10 times as fast as the old one, don't use a demo that cripples the potential performance.
Did anyone else notice he gave two different numbers for the max speed? First he said 500MBps, then at the very end he that it will operate at 5Gbps. Which would actually then be closer to 600MBps (just a tad over 596MBps).
I Wonder if there will be any hope for older laptops and USB 3....Maybe some type of card or something hopefully!
I wouldn't worry about it. Adding in a USB card is one of the simplest upgrades you can do. It's not a new CPU where you might have to replace your entire platform.
Wait 'till the end of the video, and look at the guy.
Similar?
PsyKo[H];1033578581 said:His face at the end finishes the sentence:
"You're welcome, Paul.... but now I'm going to have to kill you".
will this ever be onboard a newer motherboards?
so usb 3.0 uses a different cord?
One end is the same, the other end different.
