superPI
sht
when you run this on duel core do you open it twice or is just once ok?
thank jesse
2 copies, in 2 seperate folders.. and then go into Task Manager and set affinity of one of them to CPU 0, the other to CPU 1. You can verify you're using both cores by looking at the CPU usage, if it is 50%, you're only using 1 core. 100% of course means u're stressing both.
