What are you attempting to pass?
I wonder if it considers it a HID device
http://guardant.com/technologies/hid-mode/
Guardant dongles are able to work on the Windows family of operating systems without Guardant drivers installed. For this you need to initially switch the dongles into the Human Interface Device (HID) mode using the Guardant programming utility.
When connecting a dongle in HID mode to the USB port of a computer, the system will recognize the dongle as a standard HID-compatible device, after which the dongle will be ready to work immediately.
The operating modes of Guardant dongles in HID-mode, and those with a standard driver are identical from the user’s perspective.
It might be turned on
Can someone send them a memo to use physical x16 slots across all slots in the future? I couldn't buy this board because I needed to install my own GPU(s) and didn't want to cut the cards or slots to make it happen.
Sorry to kick in, but I tried to install ESXi 5.1 on this exact board and same cpu, 16gb of ram. During installation the screen will go black, then system reboots. Anyone got a clue?
I have been able to install without issue to this board. Have you tried updating to the latest BIOS (2.0b) and IPMI? Also, check your installation media and memory.
Ram seems very good. and IPMI and Bios are all upto date. What are you bios settings? I get windows cannot install on this hardware for installation of windows after bios reset.
