I have a Supermicro X9SCM with Intel E3 1220v2 inside a short 2U case (http://www.xcase.co.uk/X-Case-RM-204-Short-p/case-x-case-rm204s.htm this but I have the older version with 60mm fans) running 24/7 with a Zalman can controller to keep them fairly quiet
Anyway with the recent heatwave in the UK my Zalman fan mate either overheated and failed, or just failed out of the blue. And all the fans stopped, the PC over heated and my HDD died and I am surprised that was the only thing to go.
I need to replace these fans with a solution that's going to be fairly quiet when idle but will also support high temperatures and high loads and spin fans up faster when required, as this server will sometimes be under 100% CPU load for an hour or two.
My problem is that this motherboard supports PWM fan control but no fan control for 3 pin fans "Support 3-pin fans (w/o speed control)". In the UK I can find a total of 3 different 60mm fans none of which support PWM.
1) Is there a way to shutdown a X9SCM if it overheats?
2) How can I get suitable temperature control on these 60mm fans
3) Anyone know of any 60mm PWM fans available in the UK?
