Supermicro SC750 weight spec.
Commander FAT
Does anyone have a weight specification for an empty Supermicro SC750 or SC750A case? I found a spec of 49 pounds however it said gross weight. I'm not sure if that includes the packaging material.
I'd weigh my own but it's full of all my hardware.
No two different cases that's why the weight is different,
Addtronics used the dies but but not the same materials.
Easiest way to find out which case you have is to remove the plastic faceplate if has a SC 750 on the backside it is a Supermicro at 49 lbs. That's what mine is.
The other way is the side vent are not the same.
Hah, the cut out fan hole on the front is a nice touch with the tank on the side :).
