Hello all,
First time poster, long time reader. I am looking into doing a similar setup as referenced here I believe it was the ZFS Monster and several other builds. I am looking into using Western Digital 2TB RE4 drives and placing it in a SC847E26-RJBOD1 case. I just want to make sure that I can use standard sata disks not dual port sas disks with this case as it is the E26 and not the E16. (I know I won't get the multipathing, that is fine for this project) Also, would it make sense to use the LSI 9200-8e HBA with either of these JBODs?
This system will be used with Solaris 10 or perhaps Solaris 11 Express. My only other concern I have is with regards to the SES information so that I can get a port number when a disk fails, and perhaps flash the led.
Thanks,
Greg
Thanks,
Greg
