- Oct 3, 2008
If anybody experiences stability issues with these boards, such as failure to POST after a reboot - you need to disable two jumpers:
JI2C1 and JI2C2 - those are used for PCIE debugging.
"JI2C1/JI2C2 I2C to PCI-E Slot Enable/Disable Both Open (Disabled)"
Turns out, H8SGL-F can get a BIOS POST '3E' hang which was fixed for H8DGU-LN4F but not for H8SGL-F.
H8DGU-LN4F: set GPIO34 to high to fix BIOS hangs with
post code '3E' or 'E1' (IssueID=24461)
Cheers.
Cheers.
