I'm wondering if anyone else has encountered this before, just a shot in the dark. I've contacted Supermicro support, I'll see if they can get back to me on this.
Basically, I'm looking to use one of the SQ-series PSUs (e.g. PWS-920P-SQ, PWS-1K28P-SQ
or PWS-1K41P-SQ) in my 846E16-R1200B chassis.
I have acquired a PWS-1K28P-SQ, and while it is the same dimensions as the PWS-1K21P-1R it came with, the SQ PSU ultimately doesn't seat into the slot. I took a look at the receiving end and the PDB (power distribution board?) is labeled PDB PT846-8824.
Looks like the board and contacts on the SQ-series PSUs is about 1/2" wider than the stock power supply, a detail I hadn't noticed before.
Does anyone know if it would be possible to swap the PDB for one that accepts SQ-series PSUs? Any idea what part number this would be?
If anyone has a similar 846 configuration with SQ-series PSUs, I'd be grateful for a pic of the PDB that is used there.
Thanks
Thanks
