Super Pi + Hyperthreading?
Vermicious Knid
I'm trying to use Super Pi to test my pc for stability when OC'd, when I run two instances(to get 100% load on the CPU) it comes up with this error: NOT CONVERGENT IN SQR05
Thinking it was my overclock i tried it again at stock speeds, got the same error.
Is this program not meant to run on HT machines or is mine just borked somehow? or is there something special i need to do to get it to run more than one instance(like prime95 you need to edit a shortcut to specify what cpu it runs on)? What other progs should i be using to stress test?
