This is good, a great server board that could handle anything you throw at it, firewall, router, transcoding ...EVEN GAMING
- Embedded 3rd Generation Intel® Core i7 Mobile ECC processor
- Intel® QM77 Chipset
- Up to 16GB ECC DDR3 1066/1333MHz on 2x SO-DIMMs
- 1x PCI-E 3.0 x16 slot
- 4x SATA2 3Gbps w/ RAID 0, 1, 5, 10;
- 2x SATA3 6Gbps w/ RAID 0, 1
- Intel® 82574L; 4x GbE LAN ports
- IPMI with dedicated LAN
- 4x USB 3.0 ports (via header)
- 6x USB 2.0 ports (4 rear, 2 via header)
- Intel Integrated Graphics HD 4000 or Matrox G200eW to VGA via BIOS
- SATA DOM Power connector
http://www.supermicro.com/products/motherboard/Xeon/QM77/X9SPV-LN4F-3LE.cfm
http://www.supermicro.com/products/motherboard/Xeon/QM77/X9SPV-LN4F-3QE.cfm
http://www.supermicro.com/products/motherboard/Xeon/QM77/X9SPV-F-3610ME.cfm
http://www.supermicro.com/products/motherboard/Xeon/QM77/X9SPV-F-3217UE.cfm
Probably price will be a bit outlandish but for a server grade board with an embedded i7-3612QE I'd probably bite anyway.
