Anyone know of any low profile casters for a case? I only need it to roll forward and backward if that helps at all. This is for a 4u case that I am flat mounting in my stereo cabinet.
What about those "as seen on TV" furniture mover pads. They normally go under your kitchen table legs or under your couch or fridge. They are very thin (at most 1/2 inch) and very cheap.
I was originally thinking about the slippy plastic adhesive furniture jobbies, and that is still my backup plan, but the drawer idea sounds king as I don't have to worry about the case when I pull it out (assuming I can find rails that will support its weight).
Those rollers are also a clever idea, not sure how easy that would be to source, but also a valid backup plan.
And I guess as the most expensive plan, I could always get proper rackmount sliding rails, but the prices for those guys are scary.
File drawer slides that support up to 100lbs. The case weighs like 25lbs empty and with the components it will be well under 35lbs total. And for only $15 a pair! Now just to find something like this locally.
