I still have to work on my wiring, and I need to secure the pump but it's up and running!
I made a shroud for the radiator, and it is secured with some U channel type stuff I fabbed up with the aluminum sheet metal I used for the shroud. I just riveted it into the shroud. So the radiator slides into the U channel, then the shroud screws into the front of the case.
I did some work to my hdd cage so I could keep it, but unfortunately since I'm using IDE hard drives, it just won't fit. Once I go all SATA, I will be able to install it. I chopped it in half, so only two drive sleds fit in it, and I also shortened it so it would fit in the new relocated spot. I moved it back in the case about 8 inches or so.
To mount the drive cage, I made a bottom piece that is riveted into the cage, and it screws into the bottom floor of the case.
Here are the PICS!
front of the case without the bezel & front intake fan
radiator/fan shroud, without the rear fan
full setup, here you can see the full radiator & rear fan mounted onto the shroud.
here's the drive cage. the top isn't cut straight because on the cage there is this weird bubble, so I cut around the contour of it. It's not visible when in the case
Here are the PICS!
