Super Lanboy, two quick questions...
delorean76
I've had this case since Oct '05 and I've always been curious about two things: The first being, whats the 3rd yellow LED for on the front of the case?
Second, how can I use the headphone jack in the front, can I use it even if I'm not using the onboard sound of my mobo? The wire that the lanboy came with can't plug into my SB Live or anything like that.
Thanks
Yellow LED = network activity
The only way to use that jack is to make an adapter yourself.
I'm not sure if you can use the headphone jack, it seems it's actually part of that harness from what I can tell on mine from the labeling on the cables. Also.. that yellow LED is the only one that lights up on my system when it's powered on. The green one never comes on, yellow is constant, and the red flashes for hdd use. I dunno what the deal is with that. I'll look into it though.
Yellow led, extra to use with:
1. 2nd HD
2. lan activity
3. suspend
all of this if the mobo permits. The front head and mic, well thats also about the board the board or sound card need to have a inner connection for those plugs then you can connect the wires and use those plugs, dunno if i made my self clear, probbaly not.
