I know chipsets get hot, but my NB on an ASUS M4A79XTD EVO is hotter than I am used to. I run a waterblock on the cpu so it doesn't get the active cooling I assume it's expecting. In HWmonitor it only reaches ~50c but I have a thermal probe just in between the heatsink fins showing just over 65c at full load. I've not seen it go over 60c without prime95 going for a few hours, but it still worries me.
I am over volting my cpu a touch (1.37; OS shows only as 1.30), and OCing the fsb some as well, but that's it in terms of tweaks. No over volting the NB or HT. I understand the fsb tweak does add to the NB heat, but am I at risk? Would dropping my OC lower that temp? should I look for ways to add some active cooling? Should I trust HWmonitor more than the thermal probe?
