34c waking up in the morning. Easy tune says 50c, well core temp says 55c when idle. and Easy tune says 70c underload.
Ok sorry about the long reply, I was trying somethings.
Ok here is my setup: Big water
jk
D-Tek FuZion
Swiftech MCP-655 pump
Black Ice Xtreme II
1/2" DD clearflex tubing
DD 8800 GTS block
My fluid is distilled water and some D-Tek coloring.
I attached 2 antec tricool fans to the back pulling air and temps dropped to 38c idle, 57c load. Also my ambient temp atm is 22c.
There are no kinks, I will remount my waterblock, just not tonight. My pump is at the highest setting.
That's a mounting problem if its on stock voltage. Remount it and apply as much torque as you can with your hands on the screws/springs. Make sure you do it in a star pattern or else you might get an uneven mount. I'd suggest doing it 2-4 times to get an average.
Also make sure your pump is working as in do you see movement in your reservoir?
Ok I will remount it tomorrow after work. The pump is for sure working. I can see alot of movement in the res.
What do you mean by star pattern? Are you talking about thermal paste? I usually spread it on the heat spreader with my punch card. I felt like this time I was too generous on the application, but not by much.
For all those intrested I remounted. I get about 38-41 idle, and 53-56 underload. Now I am Oc'd to 3.4ghz since I hit a wall with my DS3.
