super happy Q6600 owner
skasol
Just got my oem q6600 from ebay for $150.
got it running at 3.7 @ like 40c.
I am happy. thank you all for your recommendations.
Yeah, would be good to hear some more info on the OC. Prime stable? Voltage? Cooling?
thats pretty nice especially for only $150. my quad i had at 3.7 but had to push like 1.57v through it.
sorry guys I was at the gym, I have to go to work so I couldn't run a full orthos test, (I left it running so I will find out when I get home).
this is a screenshot before I left my house
I am using a coolit Freezone that I used to use on my E6600 which I had overclocked to 4.0GHz.
I will report when I get home.
it idles around 36c and as you can see it goes up to 50c when I stress test.
I am not sure is there another program to monitor temp? I thought core temp would be the best.
any suggestions?
You're only running orthos on 2 cores also. First things first, open task manager and make sure you're showing all 4 cores.
Once you get all 4 cores running, you'll probably need to up your voltage (Checking your VID).
You got a pretty big case of epic fail going on right there. Better slow that down to stock settings and figure out what happened to your other two cores. Stability test at stock settings before going for a big overclock again.
Also you should pay better attention to what you are doing. Its fun and all to get new hardware, however you should have caught that.
I bet I know what's wrong. Make sure that you have all four cores enabled in your BIOS.
I got it currently running at 3.3 idle at 32 I will play with it when I get back from work, I was on lunch and I wanted to check it out, and you were right I didn't enable the rest of the cpu I only had 2 running at the time but now all 4 are running. thanks for the help I will keep you updated.
always with an excuse .. wow ...
skasol a.k.a. mr. excuse
Threadcrap much?
It was pointed out that he only had two cores enabled, he admitted that this was the case, fixed the issue and is now going to try overclocking with all four cores. He didn't try denying anything or attack those that pointed this out to him.
So, what's your problem?
How do you disable 2 cores in bios? Sounds like a cool idea for those of us running a Q6600 who only need 2 cores at the moment. Might get a better OC out of it.
I saw this myself once and this will happen when you installed the OS initially on a dual-core then upgraded to quad. You just need to delete the processor entry in device manager and it will reinstall with the proper amount of cores.
Hi guys I am still at work just read the email that called me Mr excuse, I am not sure what was that for, I am not making any excuses nor I need to make them, I made a mistake and indeed only 2 cores were enabled, I turn the other ones on and I left the system running, I will find out when I get home.
don't know what's so irrational about it, I made a mistake I am glad I was instructed on how to corrected and I did.
I will report later on.
Thank you all that helped.
well here it goes guys, thanks for all the help. I had to lower my memory overclock to 800 to make this 3.6ghz possible, it seems to be running stable as of right now.
idles at around 28-30c
all 4 cores enable in bios.
all of them showing under cpu-z
will let it run orthos.
any recommendation on good ram?
I currently have 4gb of ballistix 1000 ddr2.
tia
and yes orthos still running as I am typing this to you and encoding video.
this processor is perfect for multitaskers like myself and gamers.
Orthos still running for 2 cores maybe? There will be difference in temp if you run 4 cores. Also "TEST CPU" only might be better to stress the CPU.
That version of Orthos you're running is only using 2 cores. You haven't really done anything differently to stress the other 2 cores. They're showing up now, but aren't being used by Orthos.
I would recommend downloading and running Prime95 v25.6 or OCCT instead of using Orthos.
loll at this
read what the man said ^ you are not fully stressing your processor, just teasing it
Woot big time :eek:, that's the lowest price I've seen on a G0 steppin' Q6600 chip.
I just got a new OEM for $168 something on fleabay, but I'm gonna' make a 24/7 dedicated folder with so the highest I'll probably clock it is 3.2 GHz. It's runnun' happily ATM at 3.0 GHz foldin' only one client 24/7. (the temps are low and the chip seems to have plenty of "head room")
I'm waitin' on another board (Abit IP35-E, also purchased on fleabay) to add more RAM and GHz. I'm satisfied with my GA-31M-S2L board ATM, but I want to add more RAM and the giggy is a mATX with only 2 RAM slots. :p
Although I've only made like 21 or so purchases on ebay, I think as long as you stay with sellers that have a good reputation and have records of selling the same type of product as you want to buy you shouldn't have any problems. (I'm tallkin' sellin' several of the same product you want) :D
Yes. I'm secptical about that the moment I looked at it. I really hate to see a golden chip being pushed too far and becoming spoilt. That is of course, the user does not post it on this forum. Thankfully he did and hope he does get to 3.7, prime95/orthros stable.
