Sunbeam Rhoebus Extreme
freaksavior
I have this
Here are pics of the inside
Does anyone know of a way to get the knobs off? i want to mod the leds to make them red!
I have stuck it in the freezer thinking maybe the glue would break, pulled them with pliers, and got flat (litterally) and tried to pry them off that way, no lock.
I either need some clear knobs to replace those with or help getting them off.
Cant find replacement knobs like that and I looked hard even checking chinese manuf on B2B network.
you tried freezing only thing I could think of would be boiling water, difficult and still not sure it would work. Hard to tell exactly from picture but I am assuming there is absolutley no way to get that front panel off unless the knobs are removed ?
yeah, pretty much, there isnt enough space in between the metal and the pcb.
sunbeam wont return my e-mails or calls.
/agree (I had found your other posts while searching)
As I mentioned I could not find clear knobs anywhere, so if you bust them I have no clue where you can find some that will let the leds shine through with your modded color which was the whole point.
If it were me, I would be looking at trimming off some of the metal on the top and bottom "overhangs" (should not be visible when installed) and see if I could get to those LEDs from the rear. So hard to tell from pictures but /shrug.
if you found my other thread i had taken some better pics of the led positions.
im out of ideas.
