sunbeam rhk-ex-ba fan/light controller
I just put one in my Antec 1200 and have it hooked up to 6 Scythe Slipstreams. I absolutely love this thing. The only fault I can find is that the LED's are extremely bright. My next step is to disable them. But if you're looking for a 6-channel fan controller, it's a great choice.
well apparently the leds are brightness controlled depending on how much u have the knob turned up. is this the case? for me i dont think id need to turn them up much at all, i just want the ability to at my whim, including the fan on the upcoming H50 install and some cathode lighting. i mainly selected this one as the smaller original model had very mixed reviews online and the leds were all full all the time, as well as some fire hazard reports.
i take it u replaced and rewired all the 120mm intake/exhaust fans with and added middle fan? love to see some pics. my 1200 is coming next week. first step is modding the side panel.
I have this in my 590. It works very well, but the lights don't change in output very much. I bought it to replace a broken Sunbeam (the older 4 channel one).
