Hey guys... I have a question for my fellow modders... I need a bit of help.
Also, I didn't know if I should post this here or in the Electronics section.
Anyway, I have an old Sunbeam Rheobus that I've modded into a Lian Li drive cover and I wanted to use it again in my case... only not with the default red/blue LEDs. I would like them to be white and maybe another color to indicate a speed change, or maybe just white and they'll get brighter as I increase the voltage. Either way my question is what do I need to do to achieve this? Just buy the appropriate white LEDs and insert them in place of the red/blue ones? Or would this require something else?
If anyone has done this or knows how to work it over I'd greatly appreciate your input... I don't want to screw something up so I figured it best to get some advice on it first.
