Summer System Review
Please answer the sticky titled "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
With a budget of $1,200 (according to your current setup), you can go with an i7 build.
I'm looking at a $900-$950 build with a Phenom II 940 cpu, 4gig DDR2 1066, 1TB WD HDD, Radeon HD 4890 1gig video card if OP sacrifices that Thermaltake Kandalf case. I know cases are personal preference but, $280 man.
Hmm.. online posts current rig is in need of some serious upgrade there.
Yes, very serious upgrade.
I just dont want in i7 yet. Personal preference as of right now
Wow... a new FDD... for?
My old one is shit, i like to have one, some programs (i.e. memtest) use floppys.
Yes, but from reviews i have heard the case has a pretty good watercooling setup. Which i can upgrade later if needed.
I'd go for a different case, I had the thermaltake armor and it's very annoying to build with in my opinion, for example the pci toolless brackets are horrible and installing cards with screws doesnt seem to fit securely ... its an *OK* case but it's getting on now and its not brilliant. in my opinioon. The water cooling is ok but the pump makes quite a lot of noise and I probably wouldnt want the extra hassle, when high end air is nearly as good.
