Hoping for a bit of advice here,
I'm looking at building a SFF computer, because I want something I can throw into my carry on luggage. As I fly between a couple of places quite regularly. Therefore size is critical, but I also want it to be pretty powerful (I have access to screens at my destinations). I've picked the SUGO 05 for my chassis because it's only ~10l, and/but* it comes with a max 450W PSU.
I know there are a lot of folks running the 450W SUGO with OC/d CPUs and cards as powerful as the 680 without any problems, but I'm wanting to play it safe. Mainly as I'm an avid folder and we all know how hard that pushes the GPU. I got a 570 HD SC on special from a previous build that I'm aiming to bring over, for which the minimum recommended PSU is 550W...
My real question, and reason for the thread, is that I was wondering if it's possible to add a pico-PSU for an extra 120W? I thought to get a bit of extra juice into the box I could make the smallest of mods and add a picoPSU to the mix (for one thing the power pack could be thrown into my checked luggage). That way I'm giving it extra juice but only adding a minimal amount of gear into the chassis.
How to configure it is pretty mind boggling - as there are a quite few different options to power the system.
1. Get a dual power supply adapter and power the 24pin from both power sources. The 450W PSU could provide the 8pin to the mobo as well as power the GPU, as the Pico PSU wouldn't be able to power both the CPU & chipset (77W+ chipset for IB) and provide the wattage required by the PCI-e slot (75W IIRC). On the plus side if I'm not pushing the system/GPU I should be able to run it without the pico PSU if desired?
Only thing I am not sure of is whether this configuration would utilise the pico-PSU enough and instead rely on the 450W PSU to give the mobo half it's power along with all the other components? If I was wanting to make the pico-psu optional then I'd have to run all the fans/ssds off the 450W PSU as well.
2. The alternative is to configure the PSUs separately - the PicoPSU for the motherboard and fans, SSD slim line DVD etc, 450W for the extra 8pin and for the GPU. Is this possible or does it lead to dodgy frequencies from the two different power sources? Not sure whether I'll end up going down this route as now that I think about it, I kinda like the idea of running the Pico as an optional boost!
A downside to my plans is that the 570 HD SC GPU I have spare for this build has a mid-card fan, so dumps half its heat into a (regular) case. I had thought of doing a little modding to route the front of the card's exhaust out the front of the case, but wonder whether this would cause the front intake to suck in this exhaust heat... Perhaps I can fashion a 45 degree shroud to channel the exhaust out a modded front side corner at an angle to both the side (GPU) intake and front intake.
Depending on the difficulty I'm probably going to see how difficult/time consuming it is to swap between an all-in-one watercooling set up when I am at my primary residence and a stock air cooling set up when I'm in the air. From what I've read that might be a bridge too far as even the all-in-one's look pretty tricky in such a small case...
Appologies for the lengthy post, I'll keep my musing to this length at the moment!
*450W being pretty good for a case this small, but is still on the low side for my liking.
