- Sep 15, 2011
Thanks!
just keep in mind to use NUT v2.8+ to have better mitigation for occasional USB driver disconnections (a known issue with Cyberpower models for NUT).
Not sure, imwill be using a 1200w PSU in my computer, and it would also be plugging in my TV and a few external drivesHow many watts do you need?
Pure sinewave is best, as is line interactive and bypassing the battery when on AC. Cyberpower calls this "Greenpower." Reduces total used wattage.
Cyberpower CPxxxxPFCLCD (xxxx=VA rating) is my go to. Have some 1500s (900W, highest you can get for 110V).
Get a 1500VA, that's the most you can have on 110V. It gives you 900-1000W to play with "from the wall" (i.e. before efficiency losses at the PSU) and the longest battery run time. If you get the good models that bypass the battery when on AC, you can more than 900W, (silence the alarms, though), but if the power trips, it will just shut down. I'd put just the PC and drives on the UPS and the TV on a surge protector, and then make sure your PC is drawing less than 800W. Short or long power outage, you really don't care about still being able to game or work or whatever, so let the TV/accessories go out, and the PC can either wait it out if it's short, or when your battery target is reached, gracefully shut down and finish any writes to the externals. I use 80% as my target (allows me to use the rest of the UPS for charging phone and flashlight) and have my Windows power plan set to minimum power usage "when on battery" (and BOINC set to suspend on battery since I DC). It's all automatic and handles itself without me. Even important work is regularly autosaved, so no worries about not being able to do that, either.Not sure, imwill be using a 1200w PSU in my computer, and it would also be plugging in my TV and a few external drives
One other question is there a simple or reliable way to measure the maximum outlets in a room?
I live in an older building and notice that when I plug in a fifteen hundred watt space heater and run it at maximum power with the room lights on it trips the circuit breaker.
Thanks all
This is not the room.I will have my p c or u p s plug into but it makes me wonder about maximum wall outlet output
