Suggestions to reduce case rattling?
Gorilla
So the front grill inserts on my Xigmatek Elysium have the tendency to vibrate against each other which makes some obnoxious noises. I need a way to hold them in place more firmly without actually gluing them in place. Basically I need something is like chewing gum but won't leave crappy residue all over the place.
Any thoughts?
maybe something like shoe goo? It tends to peel off clean, esp. on metal.
shoe goo, RTV silicone, ADHESIVE RUBBAAAAAAA FEEEEEET, hot glue, elastic suspension vs. bolt-through or clip-through mounting (if applicable)
Beat part out of square with a big freaking hammer and force it back into it's mount so it is always under tension.
rip part out of case and throw away
put case on anti-vibration pad such as corkboard or mousepad.
mousepad (the el-cheapo neoprene, not ratpadz type) is a wonderful anti-vibration substance.
