anonimousey
- Jun 11, 2003
as the title says this is my first build in a little over 5 years. i've been doing some research the past couple days but with some of the newer technology im still feeling a little out of the loop
any suggestions would really be appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
some gaming: source, cod:mw2, starcraft II, (and maybe diablo III and the new assassins creed when they come out but not if the reqs are going to be insane)
other main usage would be audio recording. i run all my gear into a mackie 1402-vlz pro (circa 2004) and then into the line in on my current motherboard via a 2x 1/4" to 1x 1/8" line. i almost always use adobe audition to record. current setup can be a little noisy during VERY quiet recordings but not noticable enough for me to have changed anything in the past 5 years. i'd like this setup to be relatively noise free. (when i speak of noise i mean the noise on the line/audio in, NOT fan/hdd noise)
i'd like to keep it in the $1000-1500 range if possible. tax and shipping excluded
3) Where do you live?
out californee way
cpu + hsf, ram, hdd, case + fans, power supply, video card, possible sound card but only if necessary to keep the noise low. im not looking for a soundcard with 20 inputs or softsynth capabilities. all my music gear is hardware
keyboard and mouse, thats about it
6) Will you be overclocking?
most likely not
right now using an old viewsonic va720 but theres a very strong possibility i might just hook it up to my LG 42LE5500 and use that. not sure what impact (if any) this would have on my video card selection
within the next month. i am hoping to take advantage of some black friday (or newegg black november) deals for some of the parts but im not going to hold my breath
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
nothing too specific that i can think of. a clean audio in/out would be preferable but im aware that built in sound components are not always known for that. RAID, firewire and SATA 6gb/s options would all be nice bonuses but not necessarily a requirement. i know next to nothing about SLI, not sure if thats needed for most gaming systems or not
not going to use any of my current licenses for this machine so i'll need to purchase. looking to go with windows 7 32bit
thanks!
out californee way
most likely not
thanks!
