Suggestions on waterblock?
nodle
Has anyone used the Zalman ZM-WB2 Gold waterblock? I was going to go originally with a TDX or maze 4 waterblock, but I was wondering if anyone has used this waterblock before? The only downside I have seen with this waterblock is that it is real heavy. Any experiences?
The zalman waterblock is ok but not a high performance piece of gear, I would not recommend it there are better things to be had for the same amount of cash.
So you would recommend like a TDX or MAZE 4 over it? This is for a P4 btw...
If you're going with smal bore tubing, go with the Alphacool Cool.block CPU NexXxoS XP.
it's been at the top of the performance lists over in Europe for a while now.
I have the Zalman block and think it's pretty good. Load temp on my setup will reach at highest 34C. It is a heavy block but doesn't seem to have any side effects. I like that it comes with ALL the mounting hardware for different cpus. Overclockers.com gave it a very good review.
http://www.overclockers.com/articles971/
