Suggestions on upgrade. DFI? ASUS?
MRAB54
I currently have an MSI kt266a mobo w/ 2x256mb pc2100 1x512mb pc2100 and an athlon xp 1800 @1.65ghz. I'm looking to upgrade my mobo first and possibly my CPU as well. However I'm not sure about the ram because it would be kind of a waste to get all faster ram but at some point I will probably upgrade that as well.
I'm wondering which of these two mobo's you would recommend, DFI NFII ULTRA-AL or ASUS AN35N-Ultra . I would like to overclock some and reading about the mobile xp's and how well they are being pushed, I'm pretty tempted to get one of those.
I won't use SATA or RAID, and I'm not really looking for many onboard goodies as I have a sound card and NIC
card. I just want the fastest Nforce 2 board there is out there, keeping future upgrades of my CPU and RAM in mind.
I just upgraded my gf2 to a 9800pro and I want to get a little more out of that. Thanks in advance.
The AN35N Ultra is made by Shuttle not Asus, and is a very good board.
The DFI Ultra NFII AL is DFI's cheapest NF2 Ultra 400 motherboard, and is probably a fine board given DFI's record with their more expensive models. I'm not sure about it's overclocking features, but I'd assume they're there given the Ultra Infinity and NF2 LanPartyB.
The DFI has a SATA channel while the Shuttle doesnt, though the Shuttle is slightly cheaper.
I'd recommend the Shuttle because it's a known quantity to me, but I'll bet the DFI is equally good. I'd recommend the DFI Ultra Infinity over both if it didn't add features you don't care about.
my brother has the DFI board. got it in a deal with an XP2800 (retail) for 160 or so.
pretty good board. i set it up, easy to work with. he hasnt had any issues with it yet, other than user created problems. (which i unfortunately had to fix. he installed chipset drivers after vid drivers... dipwit he is)
