Suggestions on sleeving kits/tools?
cyrus360
I have an old ATX mid-tower case running a 2500 Barton, 9800 ATI gpu and a 420 watt stock PSU.
I want to practice sleeving and cable management on it and was wondering what kits are good and what tools I would need? I see a lot of them on FrozenCPU but they seem to have cruddy reviews. Especially the pin removal tools all seem to have reviews saying they break way too easily.
Any suggestions and/or tips would be appreciated. Thanks! :)
buy here, dont even consider anywhere else. takes around 6 days to get to you.
http://en.mdpc-x.com/
now their crimping tool may be a little pricy, so you might want to check out this one
for molex pins, male and female, i use this
http://en.mdpc-x.com/mdpc-sleeve/sl...ve-tools/pin-remover-4-pin-save-my-wallet.htm
and for all the other pins, ie pcie , atx, 8-pin 12v, 2/3/4 pin fans, i use a very small jewelers screwdriver. the tools that they sell to do this are expensive and break very easily, and the business end is the same as the jewelers screwdriver. some guys use 2 at a time, one on each side of the pin. it takes a little practice.
