hello community. i was picking through my box of random water cooling bits and found a couple of old xspc delta v3 blocks. these are the ones with the 1" raised square section that's supposed to be right over the cpu die. i though it might be a neat idea to lap the one block flat to see how well it might cool an overclocked x6 1055t, though i don't intend to lap the cpu. i've never lapped anything before so...questions:
1) i understand the basic principle behind lapping and have available 400-2000 grit sandpaper and 3-1 oil. at what grit should i apply the oil to the paper?
2) can i go quick and dirty with it and use my dremel to grind down the raised portion then smooth with high grit paper?
3) should i lap only the raised portion or the entire bottom of the block?
thanx in advance.
thanx in advance.
