suggestions on a SFF water-cooling setup
Luca25
im thinking of watercooling my shuttle sn95g5
however, i would prefer it not be PSU powered, as the psu is only 240w
is this possible?
heres the [H]ardware:
athlon 64 939 winchester 3200+
radeon 9800xt
1gig of pc3500
250gig sata HD
Easy. All Hydor, Eheim, Mag3 and many other pumps are made to be plugged directly into a wall outlet so no power from ur PSU to them. The only thing ur PSU will need to do is power the fan(s) on your radiator.
like he said, its possible, but (no offense) aren't you scared about running ALL that stuff on a 240w PSU? i'm sure the XT sucks mucho power....but anyway, its possible, but i'm not sure about a 3/8" ID pump, cuz u might want one (smaller tubes: less clutter, more room to work with)...but if you don't mind using 1/2", i would NOT get the Eheim 1250...because of the fact its a SFF case, you will not fit it in the case. I had to remove my sound card to fit it. But i'm sure with a hydor/via you can fit it in nicely....
good luck!
alex
killernoodle said:
The CSP 750 sucks very little juice... wouldnt hurt anything in there.
i agree, plus it has been done before.
as alex mentioned, nothing fill fit inside the shuttle, with the exception of the 750, check on sudhian media forum, there are a few watercooling projects.
i use to have 2 shuttles, one sn41g2? and a sb62g2, it can be done nicely, 1/2 id, a nice bip 120 in the back using a a 80mm to 120mm adapter, a little modding taking out the back mesh, and running the tubing to the inside. i am guessing in your case it would be a 92mm to 120 fan adapter.
i would take the fan and ice unit out, and inthe outside use things in this order.
sff>fan adapter>rad>panaflo or any 38" mm fan...cpu block inside of course, and pump inside.
thanks...any price ranges/places to get this...i looked at frozencpu and they sort of suck in terms of selection.
ive seen other sites with other stuff but no one site with everythign...suggestions?
not sure if u'll find one store with everything, that's usually pretty tough w/o paying tons of $$$ for the convenience....
pump (CSP-750) - $36.99 : http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=140
other than the BIM 80mm rad, i don't know what else to get....sorry, that's $44.99 at dangerden : www.dangerden.com
as for tubing, its up 2 u, some ppl like clearflex, others like tygon...i find clearflex is good enough for me....and if u get it, get 10' at dangerden...they give you it for $1 per foot....its $10 for 8' AND $10 for 10', so its obvious which to pick :p
as for waterblock, i would go with either the DD TDX or Swiftech M6002 (i think...forget what the exact model name is) which should run you $40-$50
and of course your random fittings, clamps, fans, etc. ~$20
so the total for now (with what i think :p): $170-ish, u could probly go cheaper
but for now, i dunno, anybody have any other suggestions/recommendations, help this guy out! lol, i don't know everything, or anywhere near :p
thanks a lot dude (i just got a birthday check from my grandma for 200 so this is a nice way to spend it...and use the spare 30 or so to get some lighting so i can get "undercarraige pimp glow" on it ahahahah)!!!!!!!!!!!!!
also, should i get a GPU waterblock as well, or with a single rad is it not worth the money/trouble...
