Suggestions on a quiet CPU Fan
potatobean
Hi guys, I'm looking for a new CPU fan to replace the one I have currently. I can't sleep at nights because of this fan. It's WAY TOO LOUD. I was looking at some fans on newegg and I was blown away by all the brands out there. Can anyone suggest a quiet fan?
computer specs:
Athlon 1.6ghz (stock, not oc)
ASUS nforce A7n8x-x
Thanks
I think he means a new heatsink-fan combination. If quiet is your priority, then Arctic Cooling has a solution for you. Lightweight, easy to install, and very cheap.
