Suggestions for waterblock
I need suggestions for a water block. I will be using a DangerDen black ice gt 240 radiator, swiftech MCP655 with speed control, Koolance VID-280 video cooler block,with the swiftech micro res. Looking for waterblock ideas: Swiftech, D-tek, or danger den? Im using an intel Q6600
X the koolance block if you want to go with a top end brass/copper waterblock as koolance blocks uses aluminum.
I use a DD MAZE5CPU and it works wonders.. It's not as flashy though but it looks mean with the solid brass top.
