suggestions for upgrade
bpimmerman
just wanted to get an opinion on what i should upgrade....
a dvd-rw(edited) drive(if so, what do you recommend keeping price in mind, 4x is fine), are there any in the 100 dollar price range that anyone suggests?
or
a bigger hard drive, my 80gig is gettin filled (which for a price/performance ratio)
i only have about 130 bucks to spend, otherwise i'd get both thanks for the suggestions.
I'd go with the bigger HD - my DVD drive is rarely used since I watch dvd movies on my PS2... if you'll be getting a DVD drive I suggest Pioneer...
oops, sorry guys, i meant dvd-rw drive, yeah, big difference there. still suggestions out there?
i would find more hard drive space more usefull than a dvd-rw drive. if you buy a new hard drive you can even rip dvds onto your hard drive, where u can convert them into xvid or divx.
