what would be so much the diffrence of a 20,000 : 1 and a 30, 000 to 1 just the color depths?
Its the brightness difference between the darkest black and the whitest white.
If a TV maker can reduce the amount of light in black by half OR if they double the max brightness (without affecting each other at the same time), the contrast ratio doubles.
As the max brightness tends to be pretty much around the same level on each Plasma TV, it is more a gauge of the brightness of deepest black.
As I mentioned earlier, you would have to be fussy to not accept double the brightness of black that I can see at 30,000:1 (ie CR would reduce to 15,000:1) and 20,000:1 is better than that.
tbh, theres a bit of a game with Contrast Ratios anyway and the measured results in laboratory testing fall way, WAY below the rated figures.
So who knows what some CR's really are.
If a TV is reviewed well (by decent reviewers), its better to believe that.
The PN50A510 seems to be pretty much unknown on the web but its specs are slightly better as it has 30,000:1 contrast vs the 50PZ80U 20,000:1
I cant tell you how good 20,000:1 is because I'm on a UK 42" model with 30,000:1.
I can tell you that blacks are very deep black on mine and even twice the light level would still be good so I cant imagine 20,000:1 being bad.
The PN50A510 has an anti glare filter and 2 HDMI ports (vs 3) so those might be your determining options.
Do you want Glossy or Anti Glare and how many HDMI ports?
Edit:
The PN50A510 is a strange fish though as it has connectivity feature that is different from all the other other screens they make.
ie instead of Viera Link, the PN50A510 has Universal Anynet Plus (HDMI-CEC)
Odd??
On your edit is that a good or bad thing?
