Suggestions for post-July 22nd build??
p4gs
well, I've definitely earned enough money this summer to buy myself a new rig. any comments/criticisms would be greatly appreciated, since this is my first time building my own rig even though i've had plenty of experience with installing/upgrading parts and i have a pretty good idea of which parts and brands will suit me well. i'm still unsure if i am making the right decision about some parts (especially the mobo, i'm not very mobo-savvy), so, obviously, i'm posting on hard forum.
I already have a good mouse and keyboard (Logitech G11 kb and G5 laser mouse), 19" widescreen LG 196BTW, and 2.1 speaker setup. I think I'm going to switch my soundcard over to my new build (SB Audigy SE), unless someone can tell if the onboard sound on the mobo I end up choosing will be a better choice?
CPU: Intel Core 2 Duo E6850 (when it comes out)
HDD: 320GB Seagate Barracuda 7200.10 perpendicular recording (http://www.newegg.com/product/product.asp?item=N82E16822148139)
RAM: 2 x 1GB Corsair XMS2 DDR2 800 (http://www.newegg.com/product/product.asp?item=N82E16820145034)
PSU: 520W Corsair 520HX (http://www.newegg.com/product/product.asp?item=N82E16817139001)
GPU: EVGA GeForce 8800GTS 320MB (http://www.newegg.com/product/product.asp?item=N82E16814130038)
MOBO: ASUS P5K Intel P35 ATX (http://www.newegg.com/product/product.asp?item=N82E16813131180)
--I really don't know if this mobo would be the best choice. Basically, I put it on my newegg wish list as a price filler; I wanted to get a decent price estimate of my rig.
Case: Enermax Uber Chakra (black) (http://www.newegg.com/product/product.asp?item=N82E16811999122)
w/ extra 120mm fan (Thermaltake A2018: http://www.newegg.com/product/product.asp?item=N82E16811999122)
I read some good reviews about the uber chakra and I ended up liking it's appearance and the fact that the audio, usb, and e-SATA plugs were on the top of the case. It fits in with my budget well.
Anyways, I plan on using it mostly for casual gaming and media. I'm definitely getting Crysis, Bioshock, and TF2. I already play CS:S a little bit with my friends and other random HL2 mods here and there. Also, school and web browsing and stuff. I would be fine with spending $1300, but nothing more. Maybe $1400 max. Right now, it comes out to $1112.84.
Any suggestions (especially about the mobo)?
thanks!
Go for some better ram, which should be around the same price ($85) WITHOUT a lame rebate. One example would be the Patriot LLK sticks. The non-kit is $10 cheaper. Ahh... you're the one who liked Corsair RAM over G.Skill. I'd take G.Skill over Corsair any day, hehe.
As for the mobo, I'd suggest either the GA-P35C-DS3R, or the GA-P35-DS3R instead of the P5K.
You're switching to an Audigy SE? Don't bother. Onboard HD Audio should be fine unless you have the $200 speakers to go with an X-Fi/X-Meridian?
