Suggestions for my WC setup
lollerskater69
I plan on purchasing these items for a Wc setup for my i7. I really wanna push this chip, lmk if the rad is sufficient. I will be using three antec tricool fans that push about 96 cfm.
I'm going to be putting the 7/16 over the 1/2 barbs. Should give me a nice seal.
Item Options Unit Price Qty. In Stock Cost
HEATKILLER® Backplate 1366 [remove]
$7.70 Yes $7.70
Breeze Miniature Hose Clamp 7/32 in. to 5/8 in. [remove]
$0.39 Yes $3.12
HEATKILLER® CPU Rev3.0 1366 LT [remove]
* Choose your fittings : x2 DTek High Flow 1/4 BSPP to 1/2. ID Barb (+4.00)
$73.95 Yes $73.95
Swiftech MCR320-QP Quiet Power 3X120mm - Black [remove]
$51.95 Yes $51.95
Dtek dB-1 Compact 12v DC Pump w/Tach Sensor [remove]
* Choose Your Fittings : 1/2in. ID high flow (default)
$43.95 Yes $43.95
Durelene PVC tubing 7/16in. ID 5/8in. OD by Saint-Gobain [remove]
$0.45 Yes $4.50
Subtotal: $185.17
Shipping: $16.70
Tax: $0.00
Total: $201.87
Why not go with a D5 or DDC3.2?
Everything else looks good I guess. I wouldn't recommend going unclamped but that's your own problem.
