Suggestions for Case Feet
houlty
Hi all, just wondering if anyone here knows of any nice case feet available in the UK?
I've currently got a Lian Li PC60 that had crappy plastic case feet, which i replaced with the AcoustiFeet (rubber), but these are impractical (they keep coming off and don't allow the case to be slid on the floor because they're rubber, although i don't want wheels either).
I like the MNPCTech Brushed Case Feet, but £30 with shipping to the UK seems too much for feet and i want to exhaust all other possibilities first.
So, does anybody have any suggestions? I've even tried looking for AV equipment feet, so please don't feel constrained to "PC" case feet.
Thanks for any help.
just go digging through a home repair store.
in the states we have home depot and lowes and a few others around the country. they should be able to help you there.
also, check out some music stores.
thanks, though since posting (which isn't long i know) what i've managed to do is get a 100mm x 1 1/4" rod of aluminum cut into 4 pieces for like £5.
what i plan to do is drill some holes through the centre, add some felt to the bottom and bolt these to my case. if all goes well i'll also try to give them a brushed look and polish them up.
i have a good idea how to do all this, but we'll see if i can pull it off. i'll post some pics if they turn out half decent. oh, and this will only cost me £6 in total, plus a few hours work maybe (which gives me something to do anyway).
