Suggestions for a powerful, smaller size GPU
t4keheart
I'm looking for suggestions for a GPU. Doesn't need to be in the RTX line, but that would be a huge plus.
I don't want a 'small form factor' size card with the low-rise adapter, but I'm looking for a card that is shorter in length, eg. something that isn't a foot long and will fit in a smaller size case. Additionally, something that does not require additional power other than what's obtained through the pcie slot, not mandatory but would be a plus.
I'm looking for the most powerful gpu that meets these specifications.
Thank you!
Without power connector, a A GTX 1650 is about your only best choice but really not worth the cost/performance
If you can support one 6 pin connector things open up, also much better performance. 1650 Super or Radeon 5500XT. Between the last two I would get the best deal.
RTX 2060 KO would be the lowest end and probably cheapest RTX card. 8 pin power connector.
Best just to go to like Newegg.com and use their search tools, narrow down to your best options and then get the best deal you can anywhere.
The MSI RX 5700 Mech OC only needs one 8 pin power connection and has 8Gb of memory on board
Card Dimensions (L x H)9.13" x 4.96"
