Suggestions for a new case
I'm in the market for a new case. My only requirements are that it has adequate cooling capabilities, a motherboard tray, and looks nice. I'd like to have a window in it as well, I can do that part myself, but if it comes with a nice one that's fine too.
Suggestions?
Edit: ATX form factor, perferably under $200.
Also, I have this case for my old computer:
http://www2.shopping.com/xPO-Antec_SOHO_SX1040_SX1040B
I'd perfer a style that looked different as I'll be keeping my current machine too.
I recommend anything Chieftec, the case's have very good airflow. I own a Matrix series tower and love it. They come with easy 80mm fan snap in mounts which are really nice. Some of them even come with a mounted fan on the side window. I looked at newegg.com for you and found a case you might like if you are worried about airflow and having a side window.
http://www.newegg.com/app/ViewProdu...1-125-224&catalog=7&manufactory=BROWSE&depa=1
I was just looking at some of the pc specs for you guys,man my server feals small now:( ,i guess i need to get my amd 2200+ out of the closet and yurn it into a server:D u guys have some nice stuff,im trying to hunt down a 128mb stick of pc100 ram for this server(having problems running out of mem on my website)any body got some they want to get rid of? i got 2 32mb sticks that work great but i need more than 64mb.....
I just bought 1 of these for a friends computer, will be buying another one for myself in a week or so.
http://www.newegg.com/app/ViewProdu...1-129-122&catalog=7&manufactory=BROWSE&depa=1
Antec Solutions case
Points I liked:
Rubber Gromets for hard drive mounting
3.5" bays (floppy and hard drive cage) are removable
Has a fan filter built into the front bezel, filter is removable, easy cleaning
Front bezel comes off with just presing to "buttons", no reaching inside to find 6 tabs to snap off
Comes with a 120mm fan for the exhaust, has a 120mm mounting in the front for intake
It's a bit smaller than my regular cases, but that's not always a bad thing.
