suggestions for a mATX minitower
The silverstone TJ08 is a nice mATX tower case. It has two 120mm fans and can hold a full size ATX psu. Its dimensions are 7.8" x 15.24" x 15.12" (WxHxD) and weighs in at 12.1 pounds. Its a nice stylish case too. It would probably hold a 8800GTS no problem but I havent heard if it would hold a 8800GTX.
The Thermaltake Lanbox was supposedly to launch December 15th but so far I havent heard it has. Its demensions are 12" x 11.2" x 17.2" (WxHxD). Its a nice looking lanbox. I think its made by Silverstone for Tt which would explain its close resemblance to Falcon's Fragbox which also made by Silverstone.
wpeng said:
Anyone have thoughts on cubes vs minitowers?
I can't speak from personal experience, but I think mini towers (especially the NSK3300) will have better cooling and airflow. It's a bit easier to mod them as well. Cubes are more convenient in terms of their dimensions. However, if you compare the volume of the Microfly against the NSK3300 or the The silverstone TJ08, you will find that they are not all that different. Subjectively speaking, cubes tend to look a bit better and may be more appropriate aesthetically.
