I haven't built a new desktop since 2004. Right now I'm using a macbook pro and it just wont cut it any more for the games that I'm going to want to play.
I will be primarily gaming, watching dvds and browsing the web. Often at the same time.
$1,600-$1,700 before tax/shipping.
3) Where do you live?
Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I have monitors, mouse, keyboard and speakers. Everything else is needed.
n/a
6) Will you be overclocking?
At first, no. After i'm comfortable with the system I will attempt to overclock, but it will only be a small jump.
7) What size monitor do you have or plan to have?
Dual 19 inch LCDs (mltisync 1940wcxm). I may get dual 22s or bigger within a year.
I'd like to purchase within 48 hours.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Firewire, good onboard sound and the ability to possibly use a 2nd nvidia card at some point in the future.
After having read other similar threads, reading lots of reviews and staring at a lot of product pages I am looking at the following from newegg:
Case: Antec P182 - 169.99
Hard Drive: Western Digital Caviar Black - WD6500AAKS 640 GB - $79.99
Graphics Card: XFX GTX 260 Black Edition - $279.99 - $30.00 MIR
RAM: G.Skill 3 x 2 GB DDR3 Triple channel memory kit - $174.99
CPU: Intel i7 920 - $299.99
MOBO: Gigabyte GA-EX58-UD5 - $298.99
The CPU and MOBO are available as a combo for -$20.00
HSF Combo: Coolermaster v8 - $69.99
PSU: Corsair CMPSU-850TX 850W - $149.99 - $20.00 MIR
OS: Vista Home Premium sp1 64-bit for system builders - $99.99
Disc Drive: Pioneer 20x DVD +/-R DVD Burner SATA Model DVR-216DBK
Cooling compound: Arctic Silver 5 - $5.99
Sub-Total: $1639.89
Shipping: $46.58
Total: $1686.47
This is right at my price point. I decided to go with the i7 build for future upgrade ability. I figure when I get the itch for new hardware in about 2 years I can upgrade a few parts instead of replacing the entire machine.
The one part that I am not 100% sure on is the video card. From the information that I can find this is one of the better GTX 260/216s out there, and this appears to be a pretty good price for it. I don't think that I need a GTX 280 for this build, even if I do upgrade to 22inch LCDs at some point(?).
Any and all input is appreciated.
Florida
n/a
Sub-Total: $1639.89
Shipping: $46.58
Total: $1686.47
