Suggestions building a PC
Trekker
Gaming, trying to play bf3 at highest possible settings, and still run smoothly.
600, no tax or shipping included.
U.S.- Atlanta, Georgia
Case, video card, psu, memory, cpu, motherboard.
hard drive, monitor, and accesories.
6) Will you be overclocking?
not at this time.
1680X1050, 22" monitor
2-3 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
on board sound, sata.
yes Windows 7, 64 bit
Go with this.
Case - LIAN LI Lancool for $59.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112323
PSU - Antec NEO ECO 520C for $49.99 w/free shipping ($10 off promo) + $5 MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
MOBO - MSI P67S-C43 (B3) LGA 1155 for $89.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130576
RAM - G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 for $41.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231424
CPU + VIDEO CARD (combo) - Intel Core I5-2400 + XFX Radeon HD 6870 1GB both for $357.98 w/free shipping
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.749295
Total: $599.94 w/shipping
Don't get a GTX 460 - it is last generation. Get a GTX 560 or GTX 560 Ti instead, if you want Nvidia. No need to go all the way to 750W on the PSU - if you are worried about 520W, either get a 620W (like the Antec ECO) or a 650W (like the TX650 V2).
HG's build is nice, btw.
That's one ugly $40 case. Oh, and it uses 80mm fans. Don't get that case.
Here's the cheapest case I'd get:
$35 - Cooler Master Elite 310 ATX, MATX Mid Tower Case with Window RC-310-SWN1-GP (Black/Silver)
The blue and other colors are $40.
Though, for $10 more, there should be better choices out there... here's one:
$50 - NZXT Source 210 -Inch ELITE-Inch Midtower Case with 3.0 USB - Black
You can also do this, swap out the case for a cheaper one and upgrade the PSU to a Antec 620C with 48A on the +12V
CASE – Coolermaster Elite 430 for $39.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
PSU - Antec NEO ECO 620C for $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
Tottal: $602.84 w/shipping
