Suggestion: Style fix
Status
Not open for further replies.
Tigsman
Im sure your everpresent template tinkerer should be able to fix this up at his/her leisure right quick
but the thread starter column in your forumdisplay template is good, I would however suggest removing the thread_starter tag and sort order hyperlink from the first column, and move it over to the Thread Starter column of forumdisplay to be able to sort by thread starter directly in your non-default column.
T
I dont see the need to sort by thread starter. Now that you can search, you can just search for all threads started by a user, or if you prefer, you can search for any post by a user. Much easier than digging though a list of threads and i would bet alot easier on the database
Status
