waltherone
- Aug 12, 2003
I'm tinkering with adding a window on my sister's case, it's just a $30 dollar comp USA case. I already made the cut, and while it's pretty straight, I've not been able to get it 100% smooth (that is, I'm not quite willing to press my finger on the bare metal and slide it along without the fear of getting a cut).
I thought of an alternative, and I'm wondering if there's anything anyone's ever seen that could be pressed/glued onto the edge of the metal. Something like a black plastic or rubber that is flexible and could just be run around the edge of the window to create a plastic/rubber trim around the window. I'm doing a high gloss paint job on the case (primer/sand/primer/sand/color/sand/color/sand/clear-coat/sand/clear-coat/sand/rubbing compound and buffing kinda paint job
) and frankly, I just admit I'm tired of trying to make that opening I cut for the window 100% perfect so it doesn't look rough on the final paint job, so I'm looking to just hide it with a thin rubber/plastic trim. Something similar to the weather stripping around the trunk lid of a car, except obviously way thinner so it isn't all bulgy and all
Any suggestions?
Any suggestions?
