Suggested Inputs/Displays
I have a Dell 2407 hooked up to my PC via DVI. I also have a Dell 1907 that I have hooked up to a second PC via DVI. I recently bought a XBox 360 and am wondering what is the best way to hook up all my devices.
I have used both the XBox components and vga to hook up to the 24" and have found that the vga looks better (but I'm not sure if everything was configured correctly). I've also hooked up the vga output to my 19" and it wasn't bad, but max res is 1280x1024.
How would you recommend that I hook this all up?
Thanks.
