Suggest me a figure...MUST READ inside...
TheRapture
Well...I am deciding on whether or not to upgrade to a newer rig...but I need to sell the "old" one first (it is a year old this month, I built it after QuakeCon 2004)...what would you think a fair price would be. The components are listed below...
-Soltek Small Form Factor chassis EQ3801, custom 92mm blowhole on one side, mesh intake "window" on the vid card side, chrome face, painted a nice blue on the aluminum parts (case cover, trim)
-AMD S754 Athlon64 3000+ (overclocks at stock voltage in this unit to 2.2ghz).
-Thermaltake "Silent Boost" all copper cpu cooler with quiet 80mm blue LED fan
-1gb of OCZ PC4000 "gold" DDR (512mb x 2 sticks)
-Maxtor 200gb ATA133 hard drive (2 years of warranty left)
-Lite-On DVD burner, Dual Layer model 2.4x
-Leadtek TV2000 Expert TV tuner/FM radio capture card
-Sapphire VIVO X800 Pro (Gigabyte bios, flashed to XT-PE) all 16 pipes artifact free, runs XT-PE clocks since day one (the card has been ran this way for a year).
3DMark2005 scores: 6231 best using performance settings. No special tweaks other than what it built into the ATI control panel.
Priced NEW at newegg.com, these parts would cost right now, $1200.00
That is a nice system!
My vote would be to ask $800 and take no less than $750.
It is used, and there is little/no warantee.
-Sky
