suggest a powersupply !
dark_light
HI
Im setting up a system. 2 * 7600GT i.e sli. 2 GB Ram. a P4 processor a couple of dvd players. a 200GB and a 320GB hardisk.
Which power supply ,in terms of watts, should i get. Will a 400 or 450watt be enough?
well first of all I would visit this link on the nvidia site that shows sli certified psu's for your needs. Its the last drop down field that says all other sli configurations. As you can see by that list the lowest power is about 550 W and most are about 600W.
Try these out;
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341001
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
http://www.newegg.com/Product/Product.aspx?Item=N82E16817128001
This is the minimum you should be spending on any psu, ths sli setup will test your psu so you should find other ways to save :)
GL!
