Suddenly it takes 20 seconds to access my raid 0 array.
Gorilla
So when I got my X25-m, I installed windows 7 on it and started using my raid 0 array for storage and some game installs (would have loved to use my ssd, but my steam games alone take up 130GB+). Anyway, for a while things were peachy, but lately I've started to have some issues. A lot of times when I go to my d: drive (my raid array) it will take something like 20 seconds for the files and folders to show up. When I try to play a song through zune it will halt for around 15-20 seconds before it starts to play (my music collection is stored on the raid array). I have noticed that after the first time that this happens, it doesn't usually occur until I have restarted my pc or it has been idle for a long time.
I don't know much about hdd so maybe this is normal, but then why have i never noticed it before?
Is this an indicator that something bad is coming my way?
It's normal.
Sounds like your drives are spinning down due to your power management settings for it.
Depending on your usage you can either choose to disable those power settings if it really bothers you that much, or if you are idle alot, leave them as is.
