Well hello!
I recently switched out my monitor for an old VGA one so I could fix an issue with it. After I got it fixed, I switched it back and hooked it up with the good old DVI cable. However, my monitor no longer picks up the DVI signal! It works fine using VGA, but I just can't get it to pick up that DVI signal. I can't think of anything that might have caused this, other than that maybe the DVI cable somehow got damaged during the time it was left unused, but I really doubt that.
So, VGA works, but DVI doesn't. Any suggestions to get the DVI working again?
I'm using Win7 64-bit and a Samsung 216BW if that helps. Thanks.
